Threads: 6
Whats the idea of the stand switch on the 636? Ive pulled mine apart before even riding it as bought it accident damaged and want to simplify it as much as possible.
Want to get rid of this switch and wiring...
Threads: 1
yup great mod. runnin tha grounded setup on my bike.
Threads: 23
doing it the other way you dont lose your neutral indicator light
Threads: 9
do you actually cut the wire that you are grounding out to the stator bolt? jus wanna make sure i do it correctly...
Threads: 22
I did this on my brothers 600rr. Just pull that wire out and then you can just put a wire inside of the plug, and then ground it somewhere.
No need to cut anything.
