10-17-2010, 11:52 PM
With all the talk of 636 tranny's blowing up because of high idle drops from neutral to first gear, I wanted to override my neutral safety switch so I could start my bike in gear. Because I unhooked my blinker pod I couldn't do it at the bars like I did on my F4i. It had to be jumped on the main harness where the pod plugs in. Overall this is really easy to do and rather than explain it in detail, below is a picture; just jump the top left plug to the middle plug and wrap it in electrical tape. Should take you longer to find some wire and electrical tape than to do the actual mod...
