09 zx6r Stunt Bike Build
My goal is to make this bitch as strong as possible and do things right the first time, because it will probably be dropped a lot...
Here's my plans
-Guesseting the frame with 5/8" thick plate
-Gusseting the subframe tabs, and rearset tabs with 5/8" plate
-Bracing the back section of the subframe with 1/8" thick plate
-Turning the stock passenger peg assembly into a subcage with 1/8" thick plate (similar to johnyp's design)
-Shorten stock front pegs so they don't touch
-Making a custom round bar (also similar to johnyp's design)
-Flipped stock cliipons
-ESD back pegs
-RSC
-Foot hole in back seat
-Dented tank (maybe not right away because I don't have a hb let alone can't do tank tricks)
-Not going to be full fairing
-Wrapped headers
-Impaktech cage
-54t rear, 15t front
-Key relocation
Yes I will be learning idle on this bike, despite it being a bad idea. I used to have a 900rr I was learning on and even had a progress thread on here. I was just starting to learn some fb control but I dropped it enough times and it cracked the motor mount on the casting. Parted her out, So I haven't been in the lot for months. But I really had fun with it and I'm here to stay.
I thought on it for a long time but I'm prepared for expensive fixes, boggy idle, fragileness, etc. I've done plenty of research on stunting these bikes so I know what to expect. And I understand they are not a beginner bike. But I've been on this bike for 2 years now and after a ton of street wheelies, a couple trackdays, and a lot of miles, it's what I'm gonna run with. Should be fun for you guys to watch, I'm gonna really expose the weakspots of this bikenot sure if that's good or bad for me yet tho haha! Oh yeah I'm documenting the entire build from start to finish on camera. Here's part 1 showing some teardown, and flipping the clipons-
Subscribed !
Nice work so far!!!
Are you sure the rear wheel won't hit that subcage? Looks close to me.
Good work otherwise
Quote Originally Posted by Tapper
Good work otherwise
Haven't checked but I think I'm alright. I doubt I'll be able to run my tire hugger though
is there any bracing in between the two sheets of aluminum thats welded to the outside of the rear peg mounts?
Quote Originally Posted by KYD
Not sure I know what you mean, but there's nothing between the two aluminum plates. Basically just two boomerang shaped pieces of alum welded to the passenger peg assembly.
hmm, just seems to me that the "subcage" would still be a little flimsy and still tweak if hit hard on the side without any support in between the welded pieces. the stock cast shit from kawi is weak even if the aluminum sheeting is strong. But i guess time will tell.
You got one cool ass grandpa! Lol looking good man, it's coming along nicely
damn bike looks good, i got an 09 also that im starting to build, prety much same story had the bike for 2 years got about 30k miles on it now im ready to beat her up, i might have to send my subframe your way when for a round bar setup!
