Threads: 1
0
Besides my technique, what else can I do keep from locking up and crashing in a huge ball of flames? I got some sticky tires already, and I used to be able to roll them no problem on my old r6 a few years back... maybe I'm too old and fat now?
Threads: 1
0
What about suspension wise? Can I dial out some compression or rebound, or maybe add some? And I thought speed kills? LOL
Threads: 1
0
If u have a Brembo front master they are touchy as hell. I have a 2000 R6 with a Nissin front master, and can roll about 100ft in 3rd, not every time though. Talk to bforeman on here. He is a natural stoppie king. He could prolly stoppie a car if he tried, he's that good.
Threads: 2
0
Set up 3 cones, one to start at, one to bring the tire up at and one where you land. Keep trying to go farther with each attempt. This was advice i've gotten from a few people and it does help. Also take some video of yourself so you and others can help see where you need improvement. I'm still far from a good stoppie roller but with some of these guys help we'll both get there!
Threads: 1
0
I picked up a Bridgestone Battlax BT016, from my buddy's shop slightly used. He told me it was a good tire, but I dunno, it seems better then the one I started on? What pressure do you think I should be running? Do you think it may be I'm just not use to having the weight of my sub-cage, 12 bar, and etc.. ? I probably just need to practice like you guys are saying. Thanks for all the help
Threads: 5
0
Pilot front tire is a must! . Just keep going at it... Take ur time and learn stoppiez . Cause going over will suck .. U will eventually hit that balance point , to we're u really don't need to be on the breaks tht much . I am hitting the Bp on and off.. But just keep going at it
