Scotts Stabalizer forked !!!
Bought a second hand scotts a few months ago and sunday while ridding its stopped working theres no resitance on any setting anyone ever stripped one or had any issues ? theres a good bit of info on scotts site but just wanted to check is this a common issue for them ????
The breakaway pin
http://www.scottsperformance.com/Stabilizer_Parts.php
Is it no 18 in diagram ???
Originally Posted by #199
Yeah
Originally Posted by GIL with 1 L
Yeah
Cheers dude time to start stripping so (the damper that is)!!!
If you flip it upside down you should see it
Do you still have to split unit to remove it ??
No......but the dowel pin is 4.5mm, which can be hard to find. I bought a 4.5mm drill bit online, and cut the solid shaft to length. Bit was $0.89, plus shipping.
Yeah
Nice quick fix was thinking to get someone to turn one on a lathe but a 4.5 drill bit shouldnt be to hard to find Thanks
