03-04 636 Neutral Safety Switch Mod
With all the talk of 636 tranny's blowing up because of high idle drops from neutral to first gear, I wanted to override my neutral safety switch so I could start my bike in gear. Because I unhooked my blinker pod I couldn't do it at the bars like I did on my F4i. It had to be jumped on the main harness where the pod plugs in. Overall this is really easy to do and rather than explain it in detail, below is a picture; just jump the top left plug to the middle plug and wrap it in electrical tape. Should take you longer to find some wire and electrical tape than to do the actual mod...
Shit is too hard...u should do it for me tomo at the lot.
or use a staple and some tape this mod does wonders homie
theres a much easier way, theres a sensor under the front sprocket cover, ground that out to a bolt on the stator cover, shamwow. same thing for a f4i.
f4i one but same concept, see that sensor circled in red, ground the wire that goes to that out.
^^^ love this guy... cracks me up with his sayings. "check this out you'll love my nuts!" slapshot
ive never said that in my life.
I know. U Were quoting shim wow. I quoted the same Guy with the slap shot. Nvm
I get it now lol.
yep, took me about 1 min and a half
