difference between o ring and x ring?
whats the difference between these two types of master links?
As far as I know, the difference between O-ring and X-ring chains is the shape of the rubber sealing rings. X-ring suppose to seal much better than standard O-ring because there are 2 sealing points.
google search results mostly all say the same thing as above quote
i thnk x's are kisses and o's are hugs or is it the other way around
every one knows x's are hugs silly ..lol
everyone knows that, and x is defense and o is offense
x-ring seals with 2 contact points, holds lube better, less friction,
o-ring seals with 1 contact point, holds lube less, more friction
You wont tell the difference at all unless you are a veteran street or mx racer, and even some of them cant tell.
Dont worry about it.
thanks guys
dont waste $ on x ring. oring is just fine
+1 go for the oring...put it on and forget about it!
It doesnt really cost much more
