difference between o ring and x ring? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: General Category (https://stuntride.the-nags.com/forumdisplay.php?fid=3) +--- Forum: General Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=8) +--- Thread: difference between o ring and x ring? (/showthread.php?tid=13650) Pages:
difference between o ring and x ring? - WheelzUp - 04-19-2010 whats the difference between these two types of master links? difference between o ring and x ring? - old man roger - 04-19-2010 As far as I know, the difference between O-ring and X-ring chains is the shape of the rubber sealing rings. X-ring suppose to seal much better than standard O-ring because there are 2 sealing points. difference between o ring and x ring? - ryan711 - 04-19-2010 i thnk x's are kisses and o's are hugs or is it the other way around difference between o ring and x ring? - old man roger - 04-19-2010 every one knows x's are hugs silly ..lol difference between o ring and x ring? - CLD107 - 04-19-2010 everyone knows that, and x is defense and o is offense difference between o ring and x ring? - Talen - 04-19-2010 x-ring seals with 2 contact points, holds lube better, less friction, o-ring seals with 1 contact point, holds lube less, more friction You wont tell the difference at all unless you are a veteran street or mx racer, and even some of them cant tell. Dont worry about it. difference between o ring and x ring? - WheelzUp - 04-20-2010 thanks guys
difference between o ring and x ring? - dlish - 04-21-2010 dont waste $ on x ring. oring is just fine difference between o ring and x ring? - 50slut - 04-22-2010 +1 go for the oring...put it on and forget about it! difference between o ring and x ring? - Bobby digital - 04-22-2010 It doesnt really cost much more |
