636 ?
#21
cool thats the i didnt do i try that see what it does
have any no how to make the 04 636 fan stay on like the f4i bypass wire that you can do the f4i are easy to do but 636 i cant find it to make stay on
Quote Originally Posted by troy
there are two wires going to a sensor on the left side of your radiator , leave them hooked up but put a switch in between the two wires so if you forget to turn the switch on it will still turn on at the factory setting ..
temper sensor thanks bro i try it not
thank for help it ran perfect now not really having boging problem appreciate it OLD MAN ROGER
