636 ? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 636 ? (/showthread.php?tid=12632) |
636 ? - JOHNNYSTUNTS - 03-18-2010 i got this motor 03-04... on a clean air mod.. its the T, left, right hose and bottom hose... on my motor the left and right hoses are gone and where they go to the motor they have plates.. i seen pics that krazy kyle has of his motor.. and his were welded.. what do i do with the rear hose... close it off or keep open?
636 ? - nj636 - 03-18-2010 keep it open to vent the crankcase, i'd throw a breather on it 636 ? - JOHNNYSTUNTS - 03-18-2010 the clean air mod with the T is sealed? it doesnt breath... so shouldnt i cap the rear hose? 636 ? - nj636 - 03-18-2010 mod with T isn't sealed, it's open... with the T you would run the crankcase hose up to the T and the crankcase vents through the exhaust. the way yours is it's sealed off on the valve cover so you have to vent the crankcase somehow. if you cap the crankcase it has no where to vent. put a hose with some sort of breather to catch whatever oily air is going to vent 636 ? - nj636 - 03-18-2010 i just did the mod but instead of a brass T i just took the vacuum line off the valve and ran a hose from the crankcase to the valve. it runs smoother throughout the rpm's ![]() the sealed way isn't bad you just don't get the added ventilation help from the exhaust 636 ? - nj636 - 03-18-2010 if this helps
636 ? - Hawaiian Eddie - 03-18-2010 Hurry up and get your 636 done Johnny. And bring yo ass down to Dallas! 636 ? - Derek-AI - 03-18-2010 wtf?!?!? youre back in dallas?? i cant keep up with ya mang....Havasu?? ill be there
636 ? - old man roger - 03-18-2010 ya what he said
636 ? - lot lizard - 03-18-2010 Don't forget to plug the airbox so dirt doesn't get to engine |
