best SF headlight
#51
so the Acerbis Vision LED wudnt be a great buy??? it has bad lightin at nite if im rockin the streets???
Quote Originally Posted by Valeska
Hmm... If it were me, I'd get a piece of black or smoke plexi, cut my shape on a bandsaw, dremel smooth the burs & edges, then use a heat gun to make it pliable, and shape it into a both accommodating & aesthetic piece of shielding to add under the lower part of that. Cover up the wires & make the headlight unit look more fitting.
Dont you know Stunter is synonymous with hack-job? That'd take too much effort
Quote Originally Posted by SA-Chris
lol! But seriously, if you've never worked with plexi, it's very easy. I've been thinking lately of making some lil pieces to cover/clean up this and that around the front end that I thought up in response to observing components being in the way when in hc or causing pain/bruises & discomfort to the legs. I'd like to make a bolt on piece, etc that smooths over that, among other things. Even doubling as a light mount & #/name plate.
Yeah. It wouldn't be too bad to make, but it'd be a bitch trying to get it to look symmetrical, and make the curves the same. It'd drive me nuts every time I saw it if it looked crooked.
Only if you drew it out freehand, lol! Sketch a shape on a piece of paper, fold it in half, cut out along one of the sides and when you open it it will be symmetrical. Trace is, then cut your plexi.
You should come on over here and help us put together our Bandit project then. We've been dyeing lexan and making windowed parts and headlights for the past couple weeks.
You can play with all the plexi you want and help us get this thing back together, lol.
this is preaty creative!!
Quote Originally Posted by foxrider6912
thats a sick creation...is this yours???
noo i just saw it somewere thought it was cool
