09-24-2009, 07:38 PM
My Righteous Clutch Review
09-24-2009, 07:40 PM
AWESOME! good to know that it wasnt meant to be like that hahahaa i will send back the perch today and wait to see what i think till i get it back.. is there any way i could get a longer lever made? ..like a inch longer and some more material machined off the perch? then it would be purrrrfect
09-24-2009, 07:43 PM
Thanks Kyle your set up looks the same as mine and i was wondering if the clutch lever was gonna be able to pull around my hand brake.. I will also wait for new version then purchase
09-24-2009, 07:45 PM
Agreed, and I really cant say much cause you obviously murder Clutch/HB with your current setup... but just from my many years of experience, everyone who i convinced to try mounting the HB as far in on the clipon as possible has loved it and said it helped them with a lot of tricks and control.
I think ur right thou about it needing to fit everyone's setup and was glad to see that you and Righteous could work together on this, in the end it will only help everyone!
09-24-2009, 07:55 PM
awesome reveiw kyle!!
![]() righteous ur the man!
09-24-2009, 08:04 PM
Nice!
![]() Longer levers are still about a month out. If you end up thinking you'll want to keep it after you get the RIGHT perch, ........pull out the grinder and do work, bro. I made it thick for ultimate strength, and there is plenty of material that can be removed for cutomization. That was my thinking.
09-24-2009, 08:05 PM
09-24-2009, 08:09 PM
09-24-2009, 08:12 PM
What I find the most interesting in this thread is Kyles clutch side grip!
Props to Righteous for taking criticism and working to fix the problems that have arisen. Set up looks good and I look forward to putting one on my bike when the time comes.
09-24-2009, 08:13 PM
like i just sent you... on pm...
what makes you think we want to put a grinder to our 80 dollar clutch perch. the whole clamp area should be machined down when the perch is fixed or a longer lever should be offered. because like i have shown. it is not able to be used like a msr in its current form. the lever doesnt even reach my grip. with my msr i have the whole flat finger are covering the grip.... thats kinda a big diffrence what do you think about this? should i just send the whole think back and stick with msr? ![]() i cant wait a month for a lever to use this perch...
