My Righteous Clutch Review
I recieved my Righteous Stunt Clutch today. I was stoked.
opened it up... thought it was funny it had a novelty sticker on it but still stoked...
I gave it a good look over... looked like it was debur'd kinda sloppy but whatever its a stuntbike.
I went to go check it out compared to my msr i had mounted up...
The lever seemed kinda short and close to the bar but i was gonna wait to install to see if maybe it worked better like that..
Once i got the lever on the issues with my setup and this lever were clear to see..
As you can see... the lever is to short for use with my brembo. The bleeder hits the bulky clamp and cant be mounted as close. you can see were my msr mounted. The areas below i think dfinetly need to be trim'd up abit
You can clearly see the diffrences in the length of the lever and the shape of the perch which causes these issues i have had with this lever.
All in all the lever does not work for me, but with some minor adjustments i think this could be one of the must have stunt parts...
I hope in the future Righteous will offer a diffrent version...
I would also like to add that Righteous has offered me a full refund and still stands behind his product. his setup is diffrent than mine, and he also runs a magura which may have diffrent clearances
thanks Righteous
thats good he refunded that. he has my respect
i ordered mine couple days ago.
I run a magura so hope mine works better
Nice fair and ballanced reporting sir...
Did you try mounting it this way?
Quote Originally Posted by hollywoodstuntz
mounting it that way wont work for my handbrake setup.
i tried
i thought it was going to be more like the msr.... but the only thing thats like it is the Leverage ratio or whatever according to righteous
good review and keep them coming.
looks like it would work good with clutch side handbrakes and people with small hands
Great review. I have a little different of a set up, so maybe it'll work for me. We'll see when I get back from ROC. Don't want to run something new right before an event. But definitely willing to try. Mad respect to Kyle and Righteous.
