One more 03 636 steel frame rebuild
This project got a little head start in summer when I had to get new forks after some kangaroo action. So that's done and only everything else remaining... This is what has happened so far:
At this point I was thinking keeping it white...
then this happened after little reinforcing... sucks when subframe bends a bit after landing on your back
to be continued
like that green homie good luck with the build
who built that frame?
Quote Originally Posted by Op4 Stunt
Stunteam prod.
That frame looks nice
Here is closer view of the frame after drying. Quality sucks but that's what phonecameras are all about
And here is rest of the green stuff
I have also shortened the wheelie bar about 10cm and dropped the suspension to professionals for maintenance and stiffening. And friend of mine is doing a new upper triple with cnc so i have more height play so the front tire doesn't destroy the radiator when I put on my "bolt tires".
Little bit more painting stuff. Black with some green sparkle.
Started putting pieces back together. Next i start building new radiator cage while waiting some parts i ordered.
Nice studs!!!!
That electric thing (not sure what it is in english) and ignition lock found its place.
Quick check to see what it's going to look like
