One more 03 636 steel frame rebuild - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: One more 03 636 steel frame rebuild (/showthread.php?tid=52264) Pages:
One more 03 636 steel frame rebuild - jep - 01-27-2014 This project got a little head start in summer when I had to get new forks after some kangaroo action. So that's done and only everything else remaining... This is what has happened so far: ![]() ![]() ![]() ![]() At this point I was thinking keeping it white... ![]() then this happened after little reinforcing... sucks when subframe bends a bit after landing on your back ![]() ![]() to be continued One more 03 636 steel frame rebuild - Duane S. - 01-27-2014 like that green homie good luck with the build One more 03 636 steel frame rebuild - Op4 Stunt - 01-28-2014 who built that frame? One more 03 636 steel frame rebuild - jep - 01-28-2014 Stunteam prod. One more 03 636 steel frame rebuild - Shane124 - 01-28-2014 That frame looks nice One more 03 636 steel frame rebuild - jep - 01-29-2014 Here is closer view of the frame after drying. Quality sucks but that's what phonecameras are all about ![]() And here is rest of the green stuff ![]() I have also shortened the wheelie bar about 10cm and dropped the suspension to professionals for maintenance and stiffening. And friend of mine is doing a new upper triple with cnc so i have more height play so the front tire doesn't destroy the radiator when I put on my "bolt tires". One more 03 636 steel frame rebuild - jep - 02-01-2014 Little bit more painting stuff. Black with some green sparkle. ![]()
One more 03 636 steel frame rebuild - jep - 02-11-2014 Started putting pieces back together. Next i start building new radiator cage while waiting some parts i ordered. ![]()
One more 03 636 steel frame rebuild - Ridick_Bowen - 02-11-2014 Nice studs!!!! One more 03 636 steel frame rebuild - jep - 02-15-2014 That electric thing (not sure what it is in english) and ignition lock found its place. ![]() Quick check to see what it's going to look like
