Where should i run my 80 in brake line
I know i saw a thread by duane s asking this but ive been looking for 10 minutes and cant find it so where should i run my 80 in line on 0506 636?
From the HB to the Rear Caliper...
Lol Let me be more specific, Where should i run it through so it doesnt look so sloppy
under frame on left side, over radiator, under throttle bodies on left side across to the right side under the fuel pump and down to the swingarm to run next to the fb line to the rear caliper
Thats basically how i had it but im afraid its going to get to hot
With your clutchcable to the tank then on the right side of the frame to the right tankmount and then under the seat plastic out to your orginal rearbrake line and then loop it around to your caliper.
This def helped me out. Thanks
I feel special that my name was used lol also remember if u remember the person that made the thread u can look under my name look at stats and u can find the thread that I started
the caliper will prolly heat the fluid in the line more than the engine would so I wouldn't worry about heat in that sense...
