Where should i run my 80 in brake line - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Where should i run my 80 in brake line (/showthread.php?tid=43281) |
Where should i run my 80 in brake line - B954Fl - 09-09-2012 I know i saw a thread by duane s asking this but ive been looking for 10 minutes and cant find it so where should i run my 80 in line on 0506 636? Where should i run my 80 in brake line - WHEELIE - 09-09-2012 From the HB to the Rear Caliper...
Where should i run my 80 in brake line - B954Fl - 09-09-2012 Lol Let me be more specific, Where should i run it through so it doesnt look so sloppy Where should i run my 80 in brake line - StuntBikeJake - 09-09-2012 under frame on left side, over radiator, under throttle bodies on left side across to the right side under the fuel pump and down to the swingarm to run next to the fb line to the rear caliper Where should i run my 80 in brake line - B954Fl - 09-10-2012 Thats basically how i had it but im afraid its going to get to hot Where should i run my 80 in brake line - Tapper - 09-11-2012 ![]() With your clutchcable to the tank then on the right side of the frame to the right tankmount and then under the seat plastic out to your orginal rearbrake line and then loop it around to your caliper. Where should i run my 80 in brake line - SPADE402 - 09-23-2012 This def helped me out. Thanks Where should i run my 80 in brake line - Duane S. - 09-23-2012 I feel special that my name was used lol also remember if u remember the person that made the thread u can look under my name look at stats and u can find the thread that I started Where should i run my 80 in brake line - rockstar - 09-23-2012 the caliper will prolly heat the fluid in the line more than the engine would so I wouldn't worry about heat in that sense... |
