05-10-2012, 11:20 AM
Well if you want it, send me a PM and I'm sure we can work out a deal! I'm not sure exactly what years it will work on but I know it fits my 06!
Thanks for the tips. I actually had a hell of a time getting the air box on, turns out the screws were a little tight. I was certain they were all on right, but I guess I'll have to check again. It almost seems like it isn't getting any air... maybe I put too much oil on the filter? The tank is a pain to get on and off though because apparently my subframe is slightly tweaked so the back bracket for it is a little off, and THAT means I'll have to get a new subframe before I make one
If you don't have a steel subframe I'd make one for you in return.
I ripped out the exhaust valve and sure enough it had a stripped gear... I'll probably just leave it out and make up one of those circuit thingies to fool the computer so I don't always have the FI light on. It still had a running problem when I started it this morning. It actually started right up but when I revved it it would studder and then when it dropped back to idle it would stall. Then I got the idea that it might be the power commander III the PO had in it. It might have been tuned for the bike when it had the other silencer installed. So I downloaded the control panel application and the map for a stock bike... then figured out what pins to put 9V to to get it in communication mode, and downloaded the map... It didn't seem to change much so I decided to take it for a spin up and down the runway. Whatever it was is gone now, I also turned the idle up a little to about 1.5-2k and that seemed to help.
Froze my ass off because it's only like 50 today, but totally worth it! I also broke 100 for my first time on two wheels!
