Threads: 0
Cool Mod Matt. Did you find your oil leak yet?
Threads: 0
If I had gages and temp gage I would be willing to try it!!
Glad you found the leak! I'm still fighting those clip on. I got the bolt drilled out, nutted and bolted both but the left just won't stay tight for more then a session
Threads: 2
thanks for explain rowdy! will deff trie it than.
Threads: 1
interesting and i thnk i'll try it...so big question is what is the actual difference between the silver and gold tape?
and DIY seems ridiculously cheaper...unless there is some sort of material that these guys have that i cant get, $30 for a roll plus a couple hours of my time is worth the over $100 you'd save by DIY instead of sending it out for some other monkey to do it for you?
Threads: 1
but what kind of 'special' tape is it? especially the gold?
with a lot of shows and burouts comes heat, my bike has gotten to 260-265 a bunch of times. dual fan really not an option but heat wrapping the headers is a poss and maaaaaybe ceramic coating them but prolly not. need to set up a few so cost per bike is an issue
