lojack got my stunter back but..... need suggestions
#31
\r\n \r\n fuck daytona.\r\n
\r\n \r\n \r\n \r\n \r\n
\r\n Originally Posted by ethiopian\r\n View Post\r\n
fuck daytona.
\n+100000000\r\n
\r\n \r\n you can detect stamping very easily! where the numbers are stamped into a frame neck, they are pressed into a slightly rounded bar that raises out of the frame a bit, i had some jag trade me a race bike f4i (which had a clean title) and a pile of parts from racing, for my crf450. he threw in a f4i frame which he said was a oem blank, with no vin, it was dark out and i just glanced at it and looked legit, next morning i took a closer look and you can tell somebody welded the numbers and ground them down (although they did a really good job) i called him up and told him to come get his bogus shit out of my garage....blows my mind how racers always point fingers at stunt riders for that shit, YET RACERS ARE THE ONES WHO ORIGINATED IT!\r\n
\r\n Originally Posted by Will215\r\n View Post\r\n
If you build frames then you should be registered with your state to get a manufactures ID# to stamp frames, the first numbers in the vin identify the manufacturer which would be you... Twite knows all the info to better explain this
This is alot of bullshit to go through for no reason, noone is going to be selling a aftermarket frame that comes with a title you can register without an inspection. 99% of stunt bikes wont pass inspection so it would be pointless. You can take the Twite frame to dmv with a clean or salvage title in fl have it inspected and they will issue you a new vin sticker and assembeled from parts title. The only problem is the bike has to be street legal, all oem safety requirements. The only thing stamping the Twite frames would show is proof of ownership.\r\n
\r\n Originally Posted by MiNi GuineA\r\n View Post\r\n
not every sate has to be inspected to be registered here in pa you go to a notery sign the title over in your name and get tags at the same time without them ever seein the bike or car that the title is for\r\n
\r\n \r\n its just a piece of mind knowin you have the title to your property so it cuts down on any hassle from any law enforcement\r\n
\r\n Originally Posted by clutch\r\n View Post\r\n
def thinkin about restamping but just dont want it to seem like it was a boosted bike and i stamped it ya kno. if i stamp it and keep the paperwork i should be ok just dont want any issues i have enough court shit as it is.
The po po can re stamp it for u\r\n
\r\n Originally Posted by j blox\r\n View Post\r\n
take it from the guys in daytona. Dont stamp it. They can tell its been altered then ur f\'d.
\n
\nTake it to the dmv with all your police paperwork. Get it properly documented on their files.
+1
\n
\n
\r\n Originally Posted by old man roger\r\n View Post\r\n
tampering with a vin is a felony dont stamp it, take it and your paper work to the dmv and they will issue you a sticker or a tag to identify the frame as yours ..
+1\r\n
someone jacked my stunter during the winter and lojack found it and when i got it back it was fine but someone shaved the numbers off the frame. i didnt have insurance on it cause its my stunt piece but what should i do now? im afraid to go to the lot with it cause if the cops show up and start runnin vins and here i am with mine missing im fuked. i have the title but not sure what to do now. minus swapping out a frame i dunno what to do. any suggestions will help oh btw its a 08 zx6r so not to many frames floating around with title for cheap.....
