My Righteous Clutch Review
#31
Quote Originally Posted by Tice
on the brembo you can just swap the banjo and bleeder and you have a clutch side master for about 100 less.......lol
ya but i like my line on top... and i loosen and flip it for bleeding.
What I find the most interesting in this thread is Kyles clutch side grip!
Props to Righteous for taking criticism and working to fix the problems that have arisen. Set up looks good and I look forward to putting one on my bike when the time comes.
whats wrong with my grip?
Quote Originally Posted by krazykyle85
I didnt say anything was wrong with it......it just made me laugh!!
Research and development creates a great product. Theres always going to be revisions especially on a great idea like this. Just we got to see how far righteous wants to go on making everyone happy lol
hee hee, i noticed it too; but thought,"da-yam, i'll run a grip like that if it gives me kyle's gangsta clutch/hb control".
good review.
like i just sent you... on pm...
what makes you think we want to put a grinder to our 80 dollar clutch perch.
the whole clamp area should be machined down when the perch is fixed or a longer lever should be offered.
because like i have shown. it is not able to be used like a msr in its current form.
the lever doesnt even reach my grip.
with my msr i have the whole flat finger are covering the grip....
thats kinda a big diffrence
what do you think about this?
should i just send the whole think back and stick with msr?
i cant wait a month for a lever to use this perch...
98% of us grind on shit to make it work, a lot of times, even on MSRs. Who doesn't spend 1-2 hours cutomizing their setup with ANY lever? If you were to grind out what you needed on the bottom side, it would still look great AND be stronger than your "slimmed down" idea...
If you don't like the current design and don't feel the replacement perch will resolve any of your issues.....then by all means, send it back in mint condition, and I will give you a full refund.
What do I think about it?....well, I love it with the correct perch....and yes, I run it on the inside, also.
It's up to you, Kyle. With the correct perch, its very SIMILIAR to an MSR. A bit bulkier and different, but very similiar, I'm sure you'ld agree. I'll send ya a perch or you can send back the whole shibang....up to you.
....just a couple small bumps in the road!
Quote Originally Posted by Questions
That's the thing.....everyone has their own two cents cause as Kyle would say..."We all run different shiet!". I made this bad boy so that you could put a custom grind notch where you need to, and still have the strongest perch on the planet. I guess its just going to depend on an individuals drive to make it work.
R&D is done for the most part. These units(with the correct perch) are bad-ass. Folks will have to decide if they like it or not.....I won't be able to make everyone happy.
damn i have no idea what you do to your shit.. but it takes me less then 5 mins with a new msr to cut off the ball tip and bolt it on and im good...
but like i have said i was under the impression it was similiar to the msr. which what i got it not. its not ablt to be used in the same way...
to me the only way someone who runs there handbrake on the inside like mine would be able to use it is if i moved my handbrake towards my grip... but then id have to cut my hb lever.
and ill say it again.. its a stupid idea to make a product were you have to notch to fit... your hb setup... you need to put down the pipe and rethink this design is my
the lever is to short and clamp is to bulky... those things need to be addressed before i would consider it a msr beater... ill return it and buy 2 msr's if the design is going to stay the same
