11-19-2012, 09:06 PM
Did you fix it?
thermastat 636 replacement
Did you fix it?
11-19-2012, 09:13 PM
fuck no its even worse think I need to drain it and try a different coolant and if that doesn't work then I think its the head gasket
11-19-2012, 09:42 PM
How quick does it over heat? LOL and your sure that you got all the air out of the system... And your radiator doesn't need to be clr'd?
11-19-2012, 09:47 PM
11-19-2012, 10:00 PM
Have you tried back flushing the coolant system?
11-19-2012, 10:14 PM
We need #'s here, how hot does it get? Does it over fill the overflow? Does it cool off if you put it in 6th and cruise around?
A little trick to help keep air out of the system is to use an aspirin to hold the thermostat open while you fill the system.
11-19-2012, 10:16 PM
How do you do that? The asprin part...?
11-19-2012, 10:37 PM
it gets up to 240, it slowly climbs up and when I ride around in 2nd it'll cool down
11-19-2012, 10:38 PM
11-19-2012, 10:41 PM
