Brembo that u can switch from 18-20mm?
#11
15? I thought they only made the 16 and 19.....so is the 15 a 15mm?
Need one that goes from 13 to 16
Those are bore sizes, these masters do not allow bore changes, they only let you change the pivot distance..
Right, I mean adjustable feel, soft/hard... that would be dope.
Changing the pivot does change the feel, so that is what these master already do...
Does anyone make them in a 13mm?
Edit: Possibly a 16mm with adjustment to feel like a 13mm
^^^ur not understanding thus concept lol
lol no I get it I just explained it like a retard. I'm saying I would love a Magura 13mm master with pivot adjustment so I could make it stiffer. Especially in the winter time when my fingers go numb.
I use the rcs 19 for my front brake. its tits. Thought about using it to try a 8 piston but it was a lot of work to swap all the shit around.
the only way i found a rcs 16 and was clutch side...the lever looked bent different so i went away, but they are the same bend
the rcs 15 is great on a 4 piston. i like it but its a tad squishier than a 16x18 but not like a magura 13. the rcs 15 does 15x18, and 15x20, and the rcs 16 does 16x16, and 16x18
