Brembo that u can switch from 18-20mm?
What master is that? Rcs? Any good for hb?
It is not a switch in the mm it switches the pivot point there is the RCS 19 goes from 19/20 and the RCS 16 goes from 16/18
that ASV lever gives you three options 20/18 and a 19 on a brembo
Got one for 150 I see them online for like 350 so I think I got a good deal just don't know how it will work
Which one did u get the RCS 16 or 19?
The adjustment say between 18 and 20
Then it is the RCS 19mm the 20 setting will be more stiff then the 18 this master will work great with a linked setup not sure if u will like it on just one 4 piston I know u and I had that convo before
Goin 8 pistons soon on the f4i
Then I think u made a good choice with the 19 RCS that way if the 18 isn't stiff enough u can just switch it to 20
sounds like a great combo to me....i rock an rcs 15 for hb
