Less than 1 minute ago
\r\n \r\n if i ever get out of motorsport withdrawl depression phase i\'ll crawl out of my hole. for now i start my gas weed-wacker up and huff the exhaust fumes.\r\n
need motard help! advice!
\r\n +1 Quote: \r\n
\n \nGet a 450 and throw some wheels/tires on it \r\n
\r\n \r\n id still throw some kind of handbrake and rear pegs on it for doing different things, sure there fun just with wheels but sitdowns and coasters will get boring in a hurry in the lot and thats about all your doing with no pegs or HB. i leave my HB and rear pegs on when i go dirt riding and it doesnt bother me a bit, its nice if im trail riding and hit some roads i can jump on back pegs and tear it up a bit. id gear it down a little unless the mx tracks you ride are really wide open. im sure ryan moore could give you a little insight on the gearing and such as hes done a honda or 2 already.\r\n
\r\n \r\n I\'ll at least have a handbrake for lot stuff.. no matter what.. circles all day for sure! gotta have a handbrake for those combos. but I have no idea what sort of handbrakes work well with this thing.. ive always used Brambo with a dual cal 4-piston set up on my 636.\r\n
\r\n \r\n stock caliper with a matched master will work great.... they weigh nothing so it doesn\'t take much!!
\n \nSaw a yzf450 with two stock brackets welded together too\r\n
\r\n \r\n id say the same, run a brembo if thats what your used to but might wanna find a way to rig up a stock rear 636 caliper like the wr250x FTI bracket\r\n
\r\n with the small caliper in the back you will want a matched hb mster , i\'ve had good luck with my magura 13mm and a j-valve , far as pegs and 12 bar / subframe ext you will have to make those , i run a 13-53 gear set and its ok but i clutch alot on the slower stuff ,oh and bark busters will save yer levers , have fun and post some pics brah , ya might look into a fan too man may hafta upgrade yer charging system tho\r\n
\r\n im gonna put an oil cooler on it for sure. and bark busters will be a must.. even tho they screw with my head when they are on there.. at least they used to. Im prob gonna get a second sub frame for the extension and 12 bar.. Im ready to get this shit goin man! Ive wanted one of these for a whiiiiile! so when your saying it s matched master/caliper set up.. im guessign that the caliper is a 13mm too.. so any 13mm master should work fine.. I might have an extra brembo I can use... maybe.\r\n
\r\n \r\n just get a dual bracket made up, heres mine.. and as suggested hit up 50 stunt/esd, sumpermotojunkie is a good site lots of hooligans and stunters on there for tips and bits..\r\n
\r\n \r\n i wana set up a wr450 or crf450!!! not sure about the others becuse.... the crf450 has lots of ready to go stunt parts pre made. and with the wr450 you can fab up some wr250x stunt parts to work. im not sure the others have any stunt options.
\n \nbut i have way too much fun on my wr250x (not to mention way too much money in it too...lol). plus thats what pretty much all the supermoto stunter are riding and theres a ton of parts for it. i was thinking about the 290xx big bore kit, i found a place that has it for 699 instead of the normal 899 or what ever. i just dont want to take away the smoothness or mess up the fact that right now the wr250x is vertualy maintance free. \n \n \nalthough i am working on maybe trading my mint 08 600rr for this mint 06 ktm smr 450 street titled and completely wired for the street \npics attatched\r\n | |||
