Friction Zone F'd up??
#11
i didnt have the problem. it was on my f2 though. I replaced springs/frictions/plates. You can usually scuff up your old plates w/corse sandpaper (or cement if your ghetto, no lie).
Did you soak your frictions in oil overnight b4 putting them in? I have no idea what is causing it.
what it seems like is when the bike warms up, somthing is causing the frictions(or somthing) to expand and the clutch tightens up, requiring more lever travel for it to disengage the clutch. If you havent pull it apart yet, do it and see if anything looks funny. (glazed plates/smokey frictions/bolts loose lol) put it back together, and try again. I couldnt find anything related on google so good luck to you man.
