I have a longer version available 35" long (most oem are 10-14" at most) and has its rotating spring metal encased inside a rubber coated metal sleeve, allowing you to secure it along a route to nearly anywhere you want! No more holding the clutch with your right hand while searching for an adjusting with your left!
How much for one of those shipped to me in Canada? And do you have a mount for it? would be cool if you had something to mount it to the clip on like a remote span adjuster for a Brembo
