secondary idle on 06 636 HELP - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: secondary idle on 06 636 HELP (/showthread.php?tid=46855) Pages:
secondary idle on 06 636 HELP - nick4ne - 01-23-2013 how do i do this... it isnt the same as the f4i.. secondary idle on 06 636 HELP - redstar - 01-23-2013 Didn't know there was such a thing.... secondary idle on 06 636 HELP - old man roger - 01-23-2013 The 636 uses the stock idle adjuster, no need for a second one. secondary idle on 06 636 HELP - Kawidillon - 01-24-2013 So while we're on the subject is there a mod to do on the 05 06 to make it easier to adjust idle ? secondary idle on 06 636 HELP - broham - 01-24-2013 how much easier could it be? secondary idle on 06 636 HELP - stunt305 - 01-24-2013 Voice activated haha secondary idle on 06 636 HELP - ScarryJerry - 01-25-2013 You could somehow get the idle set up to an Rsc maybe by combining it with a mtb shifter.? Idk But if you can't do that you need to pay a Bum to do it for you at the lot while he drinks a beer cause its easy as peeing one handed secondary idle on 06 636 HELP - nick4ne - 01-25-2013 thanks why do you have to do it on the f4i? secondary idle on 06 636 HELP - old man roger - 01-25-2013 The idle adjuster on the 636 actually opens the throttle bodies just like you were twisting the throttle, the Stock f4i idle adjuster richens the air fuel ratio. secondary idle on 06 636 HELP - SIC Nate - 01-25-2013 I have a longer version available 35" long (most oem are 10-14" at most) and has its rotating spring metal encased inside a rubber coated metal sleeve, allowing you to secure it along a route to nearly anywhere you want! No more holding the clutch with your right hand while searching for an adjusting with your left! ![]() ![]() ![]() www.sicstar.com |
