Threads: 26
bike was stunted out lot and street bike. dont have a truck. im gunna buy a street bike and completely stunt this one out. it is leaking oil and a plugg popped out. when i started it after i through it in the suv and got it home it spit oil everywhere. gotta tear it down and figure the problems out. but yea need to buy a bike for the street only.
Threads: 66
prolly put a hole in the stator thingy or whatever its called.
Threads: 26
i was guessing temperature plug got pulled out by the cage when it bent cause it bent pretty bad. luckly frame looks good no frame mounts broken.
Threads: 66
where the fuck was the oil coming from? did u lose your oil cap? it wouldnt spit oil out for now reason. again did u loop? did u have a cage on?
Threads: 26
yea sorta and yea cage. well it went rolling left to right shouldnt be too bad. the plug is where it is coming from. i think the bottom cage bar hit it busting it out of somewhere. but havent looked at it too much yet still sore. gunna streetfighter it so i can do street rides with it. and bent my front wheel (rim).
Threads: 66
the plug on the bottom where you drain ur oil from or where u fill it? ur drain bolt might have wiggles loose causing that to happen. tighten it good to go. how fucked is ur rim?
