all out f4i rebuild
#41
Quote Originally Posted by StuntBikeJake
Not only 4 calipers... (4) 6 piston calipers...
What master are you gonna use to push that much fluid???
They said a 4 piston was overkill back on the day... Then big pistons... But I seriously think this is beyond overkill and unnecessary...
I took measurements and realysed that a 20mm master on 3 of those 6 piston would have the same ratio as a 13 on the nissin 4 piston i used to run. It sirely os overkill, but i was gonna make myself a braket anyway, so y not go big, if it doesnt work i'll just take a caliper off and put 2 of em on a 16
Wow, labor of love.
