05 06 636 Big rotor adapters - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Companies (https://stuntride.the-nags.com/forumdisplay.php?fid=97) +--- Thread: 05 06 636 Big rotor adapters (/showthread.php?tid=43630) |
05 06 636 Big rotor adapters - Dr.MotoKawi - 10-02-2012 I other words like the same as the hohey adapters. I think the adapter that came with my Fti bracket is steel...if so imma order yours. 05 06 636 Big rotor adapters - 762SPR - 10-02-2012 I don't know what Hohey makes I never really look into what other companies make because I just build the parts when I need them![]() This is going to be a real simple flat rectangular stainless steel plate with two threaded and two blind holes in it. Don't know why I didn't think of it earlier... I guess I'm just not that bright
05 06 636 Big rotor adapters - StuntBikeJake - 10-02-2012 Quote:
05 06 636 Big rotor adapters - 762SPR - 10-03-2012 Oh I thought you were talking about cutting and welding in a chunk into stock bracket... Oh well, at least now you have a fancy one off bracket
05 06 636 Big rotor adapters - StuntBikeJake - 10-03-2012 No welding. Just a bolt on mod. But yes new bracket is sweet. Thanks again bud. 05 06 636 Big rotor adapters - jtownstuntin07 - 10-20-2012 I understand how this bracket works and think it's a great idea, but when you need to adjust your chain it will affect how how much brake pad is in contact with the rotor. unless there's something here i'm missing? let me know ....edit, or do you just keep a variety of different sized spacers that connect the caliper to the bracket to suffice for the offset from adjusting the chain? 05 06 636 Big rotor adapters - StuntBikeJake - 10-20-2012 Adjusting chain will not affect anything... everything is based off the axle.. and distance from the axle.. that will not change only the distance the axle is from the front sprocket. Basically you can adjust your chain all day long to any length you want and it will not affect pad contact or spacers.. 05 06 636 Big rotor adapters - jtownstuntin07 - 10-20-2012 Quote:
ok, i see what you mean, they all move together in relation to each other...duh this is a great idea btw whoever came up with it. im going to fab one for my 04 gix (I need a 636 already!) 05 06 636 Big rotor adapters - Tig - 10-20-2012 So, did anyone got to try it on a 03 04 wheel? 05 06 636 Big rotor adapters - 762SPR - 10-21-2012 I don't think it will work without modifying the wheel. JonnyP posted this picture, and you can see how the raised circle goes all the way around on the 03 04 wheels. On the 05 06 it's only raised around where the bolts go. I could design some adapters for the 03 04 wheels, but I would need someone to throw a pair of calipers across that circle and give me an accurate measurement on the diameter. Or I could just do best guess and make it big, but I'd really like to have a minimum diameter to go off of. Maybe within a MM? |
