05 06 636 Big rotor adapters
OK, hot off the mill! I've made 10 big rotor adapters for anyone that wants them. These will allow you to run '08-'10 (may be until current, I'm not sure) Hayabusa rotors on the back of your 636.
If you are running radial calipers, you should be able to use these with some spacers and possibly longer bolts because the rotor is mounted at the same offset from the center of the wheel as stock. I can make spacers for anyone that needs them and ship them with the adapter.
You have a choice of standard finish (pictured) or bead blasted for a more matte finish.
Rotor adapters are $100 shipped to the US. I can ship overseas, but it might cost extra. Send me a PM for payment info. The first two people to claim one on here get them for $75.
I'll also make you a set of aluminum spacers for $15
I should be able to ship them in the next day or two, I just need to pick up the hardware to bolt the busa rotor to the adapter. The adapter will be bolted to the hub using the stock hardware.
Dibs on first one! Sending pm!
Payment received! I'll get it out ASAP!
Thanks bud
Any chance these fit an 03/04 wheel? If so I'm in
No the rotor mounts are different on 03/04 wheels
Would require more machining on the back side to fit
very nice my friend. i will be buying one
Very nice work!
Gotta get in on this!!!
fuck i want one lol at 75 pm me info
