brakes dont bite.. - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: brakes dont bite.. (/showthread.php?tid=20405) |
brakes dont bite.. - MVSBrendon - 08-13-2026 \r\n \r\n Or you just bring the bike up to my house and we fix the problem.... Told you that last week.....\r\n brakes dont bite.. - TheFBomb13 - 08-13-2026 \r\n \r\n \r\n lol yea i know but i fixed them... and your in VT you told me to come saturday.. i cant go to your house if your not there .. well technically i can cause your my dad and all\r\n
Quote: \r\n
brakes dont bite.. - GIL with 1 L - 08-13-2026 \r\n \r\n \r\n cheap and proud ,\r\n
Quote: \r\n
brakes dont bite.. - da Liks - 08-13-2026 \r\n \r\n Shakira-Brakes don\'t bite\r\n brakes dont bite.. - sQuiD FigHTer - 08-13-2026 \r\n \r\n \r\n thats because i beat them off of her Quote: \r\n
brakes dont bite.. - 02gsxxr - 08-13-2026 \r\n \r\n I have the same problem cant even do burnouts none the less endo\'s... i\'m switching my handbrake to a gsxr or R1 radial master plus i have a clearance issue with my throttle sticking cause the F4i master is fucking huge\r\n brakes dont bite.. - TheFBomb13 - 08-13-2026 \r\n \r\n \r\n i heard gsxr radials are garbage Quote: \r\n
brakes dont bite.. - mdub4life29 - 08-13-2026 \r\n \r\n \r\n true once they are saturated no wash will take out the fluid. i know this seems janky but only way ive found works is pull pads out and get a torch and heat them up and it will evaporate the fluid. i know it is not the right way but pads are expensive and were all trying to save a buck all of my friends and i have done it and still have no problems. o and brake clean the rotors and and lightly scuff them with scotch brite or light grit sand paper\r\n
Quote: \r\n
brakes dont bite.. - TheFBomb13 - 08-13-2026 \r\n \r\n \r\n i used scuff pad and it worked mint!\r\n
Quote: \r\n
brakes dont bite.. - TheFBomb13 - 11-10-2010 searched for it but got nothing.. i have an f4i with a 600rr front end(pads, rotors, calipers) but stock f4i front brake master and lines.. my brakes dont bite hard enough.. i can't do endos or even get the brakes to lock up.. should i just got new brakes?? the rotors are straight and the pads still have a lot of life left.. and the brakes are bled fine i have good pressure in them.. am i missing something? can i clean them somehow? |
