05 06 636 Big rotor adapters - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Companies (https://stuntride.the-nags.com/forumdisplay.php?fid=97) +--- Thread: 05 06 636 Big rotor adapters (/showthread.php?tid=43630) |
05 06 636 Big rotor adapters - StuntBikeJake - 09-28-2012 Got mine today. Everything packaged up nice and individually. ![]() Test fitting everything and it looks like we are good to go.. ![]() Got the rotor bolted up to the adapter and tried to slide the adapter back onto the wheel... Need to do some light filing to trim down the powdercoat cuz its giving me some trouble, but only on 2 of the 6 bolts... Ill trim it down tomorrow and report back. Here are some pics of what im talking about.. ![]() ![]() ![]() Pic of busa rotor on adapter..
05 06 636 Big rotor adapters - 762SPR - 09-28-2012 ![]() Glad everything got there! I'm surprised you're having issues with the fit, there's acres of space on my wheel so I never would have thought you would have issues. I guess that's what you get with cast parts
05 06 636 Big rotor adapters - StuntBikeJake - 09-28-2012 That's what I thought as well. This thing is tits bud. Good job. Wish I had the ability and capabilities you have to build things. 05 06 636 Big rotor adapters - StuntBikeJake - 09-29-2012 Got everything fitted up after knocking the powder off the wheel. Gonna go test this thing out in a few... ![]()
05 06 636 Big rotor adapters - 762SPR - 10-01-2012 ![]() I love those orange wheels btw! 05 06 636 Big rotor adapters - tipper13 - 10-02-2012 Quote:
05 06 636 Big rotor adapters - 762SPR - 10-02-2012 For you guys running a stock foot brake caliper, I think I'll be able to make an adapter to use them with the bigger rotors pretty easily. I ordered up some stainless to make it so hopefully it will work out. I'll let y'all know when I have them available! 05 06 636 Big rotor adapters - Duane S. - 10-02-2012 Quote:
05 06 636 Big rotor adapters - StuntBikeJake - 10-02-2012 His bracket is one off 05 06 636 Big rotor adapters - 762SPR - 10-02-2012 Yeah, this is just going to be a plate you bolt the caliper to and then bolt to the bracket. It will have a 20mm offset so it should be able to work on any bracket that is designed for a stock 220mm rotor and adapt it for the new 260mm rotors. |
