04 636 idle problem - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 04 636 idle problem (/showthread.php?tid=40645) Pages:
04 636 idle problem - monsterzx9 - 06-17-2012 could be rubbing the Rad... 04 636 idle problem - old man roger - 06-17-2012 You would know about that pretty quick, a fan will wear through the tubes in no time. 04 636 idle problem - monsterzx9 - 06-17-2012 You would think most of the time I had mine rubbing in between the micro tubes and the actual fan bracket. But yeah i could see it cutting if it was on a tube. My buddy Truitt is religious about cleaning his TBs and I rode his bike (identical set up) and it was much much more responsive than mine... I haven't cleaned...ever. 04 636 idle problem - old man roger - 06-17-2012 The fins between the tubes are just there to transfer heat, they wont leak but if your fan blade starts rubbing on the tubes that have coolant in them they will leak. 04 636 idle problem - monsterzx9 - 06-17-2012 I've been a full time mechanic for 7 years... right there with ya bro. lol 04 636 idle problem - old man roger - 06-17-2012 My bad, I never know how much mechanical knowledge someone has so I try to break it down..lol 04 636 idle problem - da Liks - 06-17-2012 any way to go about sorting out idle problems? ordering a set of plugs tomorrow (gsxr600k6 i can choose iridium or regular ones, does it matter for the idle?) and putting in an ignition advancer, but something tells me it should pull just fine on idle. motor supposedly has 7000 miles, but has been raced. 04 636 idle problem - monsterzx9 - 06-18-2012 I do the same thing... I will be explaining a water pump to a guy and he stops me and say bro I owe matco 5600 bucks lol. 04 636 idle problem - old man roger - 06-18-2012 I was telling some one about a tankless water heater and then remembered he was an electrician
04 636 idle problem - da Liks - 06-18-2012 roger, does the choice of plugs matter? iridiums or normal? i can get both for my bike, irids costing twice as much.. |
