Threads: 6
0
When is the last time you put a set of plugs in it?
Threads: 10
0
Put an air filter back in it.. lol.
Threads: 6
0
There are so many possibilities it's hard to diagnose over the net.
Common causes I have seen on this forum are
Water in the gas
Plugs
Clogged pump
Corroded electrical connections
Bad harness
Bad battery
Bad tps
Loose throttle bodies
Throttle bodies out of sync
Bad coils
Hell the list goes on and on.
Threads: 6
0
I've even had a fan motor going bad cause the bike to run shitty.
