Just bought a drz.. help me set this up - Printable Version
+--- Thread: Just bought a drz.. help me set this up (/showthread.php?tid=33030)
Just bought a drz.. help me set this up - Stubbz63 - 10-24-2011
a number of guys stunt the drz im sure you can find some info on here or on supermotojunkie.com in the ryan moore section
Just bought a drz.. help me set this up - *MeatballStunts* - 10-24-2011
I didnt even know supermotojunkies had a stunt section.... Ill have to check that out.
Just bought a drz.. help me set this up - Stubbz63 - 10-25-2011
anything in the ryan moore section is basically stunt stuff, lot of good info can be found for motards over there for sure
Just bought a drz.. help me set this up - onelegstunter - 10-27-2011
Originally Posted by drew"db"beck
Originally Posted by DJFireUSA
Looking for following setups... search not working
Drz400sm
Cage
Hb
Anything else?
This is what stubbz said to another guy asking a similar question
nothing available for them man, cage is made one of nothing in production but PM onelegstunter he might be able to send ya pix of his he made. handbrake probly junction valve is only thing available i dont think theres a DCB out there. skip the cage get stiff driver pegs and axle pegs for protection and handgaurds, build your own roundbar and get an RSC you should be good.
im running a 12 mm magura hb,with a straight line to the caliper... 12 mm better cuz of the small piston in the dirtbike caliper... tex me ur number and ill send you picts of a home made dual caliper set up you can make very very easily.. it bolts up to the rotor gaurd that you must remove to install. i run a righteous and its butter .... get the long lever and the spacer... i got pro taper fat bars and a 160 pilot on back and pilot on front.. i got picts to show you how to mount up pegs... and i put a ugly undertail exaust on mine with a iron foot plate in the middle of the round bar subframe.. i also cut 3-4 inches of my seat and installed a diamond plate to stand in for seat standers and stepping to other tricks... keep ur stock front master cuz others will overpower the front calipers and cause inconsistant braking... i put a sick ass wrap on it and you can see it on the front video on the stuntride site under the roc vid.
others here in kc run a 13mm magura thru a junction valve and seems to work for them. i go thru bill at fullthrottle.inc for all my stuff i cant get hooked up on from others... this is by far the funnest bike ive riddin and i stunt street daily and get bored in the lot honestly... but i can do o's too... for the street i run a 13 front sprocket which is stock on the drz400e and the stock 41 tooth rear... and the lot i run a 14 tooth front and a 65 tooth rear so total of 68 lol ... it pulls like a freight train... and will post a video of it tomarrow i been editing a real killer here in kc... jesse johnson...
others will disagree but its up to you to find out what works best for you ... and trial by error is the best teacher... dont b scared to break nothing on that bike its a dirtbike its indestructable lol .... ive broke it all.... but i deal with mobility issues so its big mental blocks for me... tex me 816 213 6518.....
here check out this street action on the drz and lots of other bikes.... we went H.A.M in st.louis this year.....
Ride Of The Century 2011 ROC Street Bike Stunts Blox Starz Bloxstarzlifestyle.com - YouTube
Just bought a drz.. help me set this up - JohnForLife - 10-27-2011
put a one down, and call it a day thats all you need. no hb no bar no cage. stiffen the suspention up.
i miss mine
Just bought a drz.. help me set this up - *MeatballStunts* - 10-27-2011
onelegstunter... thanks for the info.. very helpful ill text you
And John... Id like to try to make some kind of lil footbar in the back and a handbreak and it should be setup just how i want it. But the bikes a blast I love it.
Just bought a drz.. help me set this up - turtle - 10-27-2011
i miss mine
+1 ....Dirt bikes don't need a handbrake
Just bought a drz.. help me set this up - Stubbz63 - 10-27-2011
they do if you actually wanna do more than basic shit on um. off peg coasters any form of off peg O's. streetbikes dont need a handbrake either but you all ride with one. whats the difference.
I apologize ....that was a ignorant statement on my part.
