03-04 636 Neutral Safety Switch Mod - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 03-04 636 Neutral Safety Switch Mod (/showthread.php?tid=19481) Pages:
03-04 636 Neutral Safety Switch Mod - motobruce - 12-16-2010 Whats the idea of the stand switch on the 636? Ive pulled mine apart before even riding it as bought it accident damaged and want to simplify it as much as possible. Want to get rid of this switch and wiring... 03-04 636 Neutral Safety Switch Mod - iRiEsTuNtAh! - 12-19-2010 yup great mod. runnin tha grounded setup on my bike. 03-04 636 Neutral Safety Switch Mod - redstar - 12-21-2010 Thanks for that. I was curious how to get it to start up in first without that whole wire harness. I used a staple as mentioned by duane. 03-04 636 Neutral Safety Switch Mod - 1997f3 - 12-21-2010 Quote:
I haven't even touched my 6 yet! this mod is on the list for sure!!!
03-04 636 Neutral Safety Switch Mod - old man roger - 12-21-2010 doing it the other way you dont lose your neutral indicator light 03-04 636 Neutral Safety Switch Mod - WiseGuy - 12-28-2010 do you actually cut the wire that you are grounding out to the stator bolt? jus wanna make sure i do it correctly... 03-04 636 Neutral Safety Switch Mod - redstar - 12-30-2010 I did this on my brothers 600rr. Just pull that wire out and then you can just put a wire inside of the plug, and then ground it somewhere. No need to cut anything. 03-04 636 Neutral Safety Switch Mod - TWITCH101 - 02-27-2011 Quote:
03-04 636 Neutral Safety Switch Mod - old man roger - 02-27-2011 Quote:
03-04 636 Neutral Safety Switch Mod - TWITCH101 - 02-27-2011 alright thanks |
