08-05-2013, 09:52 AM
2000 GMC Sonoma SLS xcab 4x4 in PA, Cheap. Needs some work
This was an awesome stunt hauler, figured I would throw it up. Willing to part it if it doesn't sell.
Black exterior
Black/Grey interior - All stock - good condition
135K miles on chassis
40K miles on engine
4.3L auto
New tires
New motor mounts
New Exhaust
Heavy Duty eiton pozi rear w/ new ring & pinion
New HD universals & axles
New fuel tank, fuel pump, fuel filter
New cap/rotor & wires & distributor
Fresh Fluids/Filters
Fiberglass hood
Truck needs: (price reflects parts/labor necessary for inspection)
-Wiring harness re-wired or replaced. (original owner had an aftermarket remote starter installed that is conflicting with the main harness after the new engine was installed) Currently the truck will not run until wiring is completed.
-Upper fan shroud & Fan need to be replaced (upper shroud fell into fan and cracked the shroud and one of the fan wings)
The engine was purchased for $1100 - I may have put 300 miles on it, if I'm lucky. I made sure the 4x4 worked and everything ran great when it was running, just needs to have someone go surgical on the wiring harness.
$1700 - Clean Title in hand! - Price is FIRM but open to trades - serious inquires only. I really just do not have the time to part this truck out, or fix it. Thank You.
List Date: 8/5/2013
For more info, click here to view the original listing: 2000 GMC Sonoma SLS xcab 4x4 in PA, Cheap. Needs some work
On Sale For: $1700 + $0 Shipping
Black exterior
40K miles on engine
4.3L auto
New tires
New motor mounts
New Exhaust
Fiberglass hood
List Date: 8/5/2013
