Adjustable clipons with 929 fe on f4i ?'s
What length front brake lines should I get? I have the stock 929 brake lines & they are to short.
I heard that its best to run 929 throttle cables with this setup because they are longer & keep from binding?
Anybody running the Stunter X Resis with Adjustable Clipons? I noticed i might need to run a longer tygon hose if I want to run these at the height Im wanting to run them?
Im thinking of buying a 1000rr kill switch & I bought one of those universal throttle tubes from cycle gear, it looks similar to the 1000rr throttle assembly. Does the 1000rr kill switch plug right up to f4i?
