Threads: 12
0
can some of you do a quick measurement and tell mehow wide are your bars from tip of one bar to tip of the other?
also how long are eacj clipon?
i think mine are too narrow. i'm runnin lsl. and from tip to tip i'm 29 1/4
my bars are 12 but they're mounted way inside the clamp.
Threads: 5
0
My bike isn't with me, but I swear its around 34 maybe. I run vortex with Thorpe adapters. 11.5 inch barsI believe flush on he inside of the vortex...
Threads: 27
0
My Protapers are 31" tip to tip...
Threads: 7
0
34" wide overall for me, 14" long tube, i run a tigershark on an f4i and they rarely touch the ground
Threads: 12
0
How ever wide a standered size door my clipons are 1/2 inch wider
Threads: 22
0
This thread doesn't make sense depending on how turned in someone's clipons are the measurements will be smaller if u want an accurate measurement it should be from where te tube clamps to the tip of the tube
