05 636 Gauge mounting ideas??
I got mine mounted with ties on the cage but it rattles and is really annoying any ideas?
More zip ties? I have mine like that but with another zip tie closer to the buttons and it's solid.
Aluminum strap at home depot looks clean check my shit out
So checked fuck need update my pics but where the intake in the frame is drill a hole for a bolt and the back side of the cluster there's a place to put a bolt use 6 inch of aluminum strap they come in def thickness o make sure you run lock washer in the frame but don't worry your filter will stop it if it does fall and your bars clear and cluster stays in one spot I'll try get a pic later
