Any Tricks to not breaking rear sets???
\r\n \r\n ESD\'s\r\n
\r\n \r\n Hohey!!!\r\n
\r\n \r\n just got a steal on these vortex so i thought id be golden, but damn i guess i might have been better off payin out\r\n
\r\n Originally Posted by Paul\r\n View Post\r\n
ESD\'s
+1.....have yet to see a set of ESDs bend/break, or even tweak. Super solid.
\r\nOr......shorten your pegs on whatever you use, to the point that you can lower your bike to the cage...and the peg doesn\'t touch the ground.\r\n
\r\n Originally Posted by Righteous 1\r\n View Post\r\n
This ^^
\r\nThe right sides on the 05-08 are like balsa wood.\r\n
\r\n Originally Posted by Cameron$\r\n View Post\r\n
Stock, vortex, you name it, takes a couple pancakes and its done, is their any tricks to not breaking them, ive heard some people trimming them down a little bit, but curious what all you guys do to prevent this, i know not dropping the bike works the best but...
\r\nalso i run a FI cage and a SI subcage...
\r\ntypically its the right side.
Shorten the pegs
\r\nMake sure the pegs fold easily
\r\nGet steel rearsets that give a little bit instead of breaking.\r\n
\r\n \r\n It\'s not the rear sets lengthen your sliders on cage so your foot pegs don\'t hit the ground. Also shorten pegs like mikey said. For same purpose\r\n
\r\n \r\n Shorten the pegs and run some ESD or HHD\'s \r\n
\r\n \r\n definitley cut your pegs short. also make sure your shift and brake pedals dont touch, my brake pedal dragged when i laid the bike down and ended up ripping the internals out of my foot master\r\n
\r\n \r\n recently got the ESD\'s but their pegs are super short so threw a set of bicycle pegs on them that are longer, hope they don\'t cause the rearsets to break if i drop it
\n\r\n
