what brake shoes do you use?
i have been having alot trouble with my oem shoes. i did the mod and it worked pretty well for a while but no i cant really even feel any braking power. so i ordered some kitaco shoes and they are in the mail. just wondering what shoes you use? oem, kitaco, ebc or any others?
Still on my original ones from 02 lol
did you shave down the bottom shoe and do the mod? i just wonder if that wares it down alot faster. or the fact that i can be a straight brake raper
whats this mod you speak of
shave the bottom brake shoe down where it hits the cam and it makes your brakes work ten times better. but for the front what i found was if you do this mod it doesnt work, i did not take in account that the brakes in the front are turned and on the oppisite side of the bike. so if you do the front grind down the top brake shoe where it hits the cam shaft. i think it just wears down your brakes faster because it works better.
yup.
im pretty easy on it i guess
just bought my first fiddy like two days ago, and I've tried everything and the brakes are almost useless. I dont know if it's normal or if i need some different shoes
its normal there is either a sticky on here or stuntlife that says fix your brakes for free. read it and works very well.
did the mod works great
I tried, but i guess I'll try it again and take a little more material off
