Coolant mess
My bike it's leaking a lot of coolant, specially after each wheelie when it releases a cloud of smoke which smells like somethings burnig. I can't find the source of the problem, guys help out here before my wallet burns out of life. ALL IDEAS and SUGESTIONS are welcome
Put the radiator cap back on.
put coolant in. bleed system (cap off, turn bike on for 3-5 mins letting air breathe out), turn bike off, let cool, fill with coolant, and repeat once or twice. if still having problems maybe new water pump, maybe flush radiator/coolant system, maybe new rad cap...
question is. what have you tried doing to fix this?
Step one find out where its leaking from lol
loose hose? hole in the radiator? loose radiator cap?
might just be overheating and steaming out through the vent. can't really diagnose anything based off of your description.
what temp ur bike runnin at when this happens?
Could be a loose cap or mis adjusted cap. Mine was leaking last weekend. Let it cool, popped the cap off then popped it back on and it stopped.
check your coolant overflow res. sounds like maybe its leaking from there and then touching your exhaust pipe and smoking, just a thought..
Thanks a lot guys! I took a look under the bike and it appears that a hose feeding the radiator it's broken....Tomorrow I'll take off the plastics and cage to take care of the problem.
