05-04-2012, 06:53 AM
My sub is hooked up and everything, using a LOC (line output converter) currently i am only tapped onto my rear left speakers. Would it be better/different if i tapped into my right speakers as well (combined with my left).
With my knowledge of electronics/audio. It shouldn't make a difference whether i tap into just the left or just the right. 1. because subwoofer is mono 2. because the frequency/current should be the same, even if i added sides right?
I was just wondering if i'd get a better signal if i tapped both sides vs. just rear left.
and how do i check to see if something is grounded properly, i have a multimeter and know to set it to ohms. one terminal to the ground on amp and the other to where i want to ground correct?
