best cage for stunterX steel frame?
me n smokey636 got steel frames for the 2012 season. yet we both need new cages...need suggestions on which cages to get ... positives an negatives with cages. thanks
Chris lints , jered , and cisco all have sick innovations as far as I know and they seem to be just fine , and those fellas are not gently with their bikes !!!
I like the SI cages on the steel frames. The tubing on both looks similar and kinda looks like one whole piece when frame and cage are powder coated the same color.
I have a SI cage for sale in my 636 part out thread
IMPAKTECH my man!
Well now u have a steel frame, what do u need all of that supposed "Extra" protection for? Big cages = weight and with a steel frame u just added enough dont u think? The lighter the cage the better. The SI cage looks great and performs even better. Plus it follows the lines of the tube frame theme
Race rails on FF = clean !
U got a steel frame......so basically, your just keeping the pegs,bars,motor covers off the ground......
It dont get cleaner than this!
It does look like you just cleaned it
stay away from Tygershark if you're shaving weight. They're heavy as fack!
