\r\n \r\n pretty sure that ktm\'s are still carbed... rode some borrowed ktm\'s and i\'m not a fan.
\nif you will go with carbed one then husqvarna smr 450 or 450 RR is way to go.
\nThe bikes will offer a TIG welded frame with adjustable steering head just like on the official Team Husqvarna machine as well as a shortened, black anodised swingarm to improve traction and manoeuvrability. The one-piece steering plate is made from anodised Ergal and the increased diameter steering pivot is in aluminium.
\nThe RRs will have Alpina tubeless STS rims with a 120/70 x 16.5 tyre at the front and a Dunlop 170/55 x 17 slick at the rear. The brakes are the real news item for this year with a one-piece caliper and pump.
\nThe SM 450 RR and SM 530 RR have "Wave" discs with a 310mm disc up front for a better compromise between adjustability and stopping power. As regards suspension - up front there are 50 mm Marzocchi forks with a sealed cartridge unit and anodised black fork bottoms while, at the rear, there is a Sachs racing aluminium-bodied shock absorber and the frame is painted black.
\nThe more powerful "race" engine is mated to a six-speed box derived from motocross versions as are the STM slipper clutch, the electric starter, the 41 mm Keihin carburettor and the special cams and pistons. In collaboration with Arrow, Husqvarna engineers designed a tailor-made exhaust system for the SM530 RR. Like that on the SM 450 RR, it is made from titanium and features twin silencers. The heat shield is also made from titanium.
\nThe twin-coloured anodised aluminium filler cap is new as are the anodised Ergal racing handlebar clamps. These are one-piece items bearing the legendary Husqvarna name. The motorcycles come supplied with spare sprockets and crown wheels and a set of steering rake sockets as well as a racing type side stand, racing brake and clutch levers and hand guards The machines are not homologated for use on the road and can only be ridden on a track. They will be available from early December through orders made through the Husqvarna sales network.\r\n
