04-12-2011, 04:48 PM
4cyl, auto, has around 124,500 on the OD but I figure I will have around 125,500 since I am going to be taking a road trip to mass, and back next week. Car has knock at startup , gos away after about 2 minutes of running/after the car reaches about 120 degrees on the coolant side. I figure its one of the pistons moving around hiting the cyl walls on startup. Runs good otherwise, new tires, brakes, radiator, alternator, starter,plugs,wires, A/c and heat work no real issues otherwise. The only reason I want to get rid of it is because I want a small turbo car. Bulgarian Mike was the first person I spoke to about the car but if he doesnt want it I figure I will leave it up on here if anyone wants in.
I want 2k for it the rolling chassis alone is worth that cause its in fairly good condition, or if you have any trades I would be willing to put money on top of my car for your trade. The truck has a Clean title.
