Threads: 23
0
i know there is screw type seal remover for the seal at the shifter i would assume there is one for that seal too but im guessing ..
Threads: 0
0
replaced more then once take a hook type pick and hook through seal (its fcked anyway)and pull..been popping some tires?
Threads: 0
0
use two drywall screws it will push against bearing race and pull seal out it's simple i do it with a screw driver
Threads: 10
0
Drill a small pilothole on top and bottom of seal don't go to deepe just stop once u get thru the outter part of the seal, its sheet metal under the rubber. Screw two sheet rock screws in till u feel them barley touch bearing behind, jerk out with vice grips.
Threads: 18
0
i replaced mine , came out real easy, just used two screwdrivers to pry it out
Threads: 9
0
yes it can be done i have replace 2 of them....
Threads: 18
0
good thing i parted out a 636 motor recently and had another seal laying around, the old one was so destroyed have of it wasn't even there, so it came right out, no more leak:-)
